Whipsnade
Dec 28, 2022Aspirant
RAX45 Configuration Restore Fails
My RAX45 recently corrupted after a firmware upgrade attempt. After finally resolving that I attempted several times to restore configuration using several cfg files that I religiously create everyt...
- Dec 28, 2022
Yes, for a R7000, R7800, and R9000. Each time I made sure the backup configuration file was created under the same firmware version I was trying to restore to.
Backup configuration files are not necessarily interchangeable between firmware versions.
Kitsap
Dec 28, 2022Master
