billrobpv
Mar 23, 2021Tutor
rax45 delete (close) a guest network
I have an RAX45 nighthawk and windows10. I have somehow created 2 guest networks, one on 2GH band (admin) and a similar one on 5GH (admin5g). I want to get rid of them, but deleting the names, etc....
- Mar 24, 2021
I've seen it before where a bug leaves the guest network enabled. Not sure if thats the case in yours.
You can always try a factory reset. Push and hold reset for 7-15 seconds while its powered on. Then reinstall it.
See if that fixes the issue.
billrobpv
Mar 23, 2021Tutor
I forgot to add that guest betworks are NOT enabled, and I have unchecked all the option boxes that I could. billrobpv
