DrFast
Apr 05, 2024Aspirant
RAX45 Double NAT with 2 X boxes hardwired - Optyx fiber
Hello all, We just switched from Spectrum to Optyx 2gig fiber. Now we are always seeing Double NAT making multiplayer games lag significantly. Here is our setup: Our Fiber provider setup...
- Apr 20, 2024I have Optyx fiber as well and have the same issue but I’m using there modem/router (EERO Pro 6E). Called them the other day and they said that are having problems with double NAT and that you can buy a Public IP address for an additional $10 a month.
Apr 05, 2024Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
I'd also press the power button on both xbox consoles until they shut off, give 10 seconds then turn back ON. This might clear out any odd networking behaviors.
Also if you have two xbox consoles on same router, I'd set NAT Filter on the router to OPEN.
Be sure the ISP is not blocking any gaming ports or configurations as well.
