K-Med
Aug 02, 2020Aspirant
RAX45 Firmware Auto Update/ Update From Within GUI
Hey guys, this post is actually about an RAX45, but regardless I can't seem to get this router to update it's firmware from within the GUI without doing so manually. The check firmware button works, ...
Aug 03, 2020Guru - Experienced User
What modem is it connected to?
the only other though I'd have is its kind of actually a good thing. I see the most issues with corrupt firmware using either the auto update method, updating over wifi, or updating via the app. I usually recommend people disable the autoupdate and do it manually for the best results.
K-Med
Aug 03, 2020Aspirant
It's connected to a Technicolor modem that I've put in bridge mode. Never had an issue with my Asus updating automatically, just weird. Pretty disappointed thus far with this RAX45, but who knows..maybe it'll grow on me.
- plemansAug 04, 2020Guru - Experienced User
Which technicolor modem?
And not all bridge mode's function as they should. (sadly)
