Lqd96
Jul 09, 2020Follower
RAX45 Firmware error and wif drop on laptop
Hi, I just bought the RAX45 about 2 weeks and ran into these 2 issues. I am unable to check for firmware update. Keep getting the Firmware check error message. Another issue is that the WIFI on my ...
Christian_R
Jul 15, 2020NETGEAR Employee Retired
Hi Lqd96,
If you recently purchased the device, I would recommend contacting our support team by registering your device using the link below.
https://www.netgear.com/support/default.aspx
Christian
