j-d-m
Jul 02, 2020Tutor
RAX45 Firmware Error (GUI language table)
I'm unable to update from 1.0.2.20 to 1.0.2.28 because of an invalid GUI language table. I waited a few days to see if it was a server issue but still getting the same error. Is anyone else having th...
DonSaavedra
Jul 02, 2020Tutor
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Found this, may help to update manually
- j-d-mJul 02, 2020Tutor
Thanks for the link. I'm also glad to know it isn't just me. Hopefully Netgear engineers can get on fixing this.
- SCharlieJul 17, 2020Initiate
I am having the same issue with the language file.
I had the problem with 28 and now 32 updates.
I did this firmware update manually but I would really like it to work through through Safari, Chrome browsers.
This needs to be fixed so we can update easier.
- mbruni13Jul 19, 2020Tutor
In the same boat here :(
