j-d-m
Jul 02, 2020Tutor
RAX45 Firmware Error (GUI language table)
I'm unable to update from 1.0.2.20 to 1.0.2.28 because of an invalid GUI language table. I waited a few days to see if it was a server issue but still getting the same error. Is anyone else having th...
j-d-m
Jul 02, 2020Tutor
Thanks for the link. I'm also glad to know it isn't just me. Hopefully Netgear engineers can get on fixing this.
SCharlie
Jul 17, 2020Initiate
I am having the same issue with the language file.
I had the problem with 28 and now 32 updates.
I did this firmware update manually but I would really like it to work through through Safari, Chrome browsers.
This needs to be fixed so we can update easier.
- mbruni13Jul 19, 2020Tutor
In the same boat here :(
- j-d-mJul 23, 2020Tutor
Same here. The hotfix update worked fine when done manually but now 32 is failing when downloaded through the router settings page. This is really pretty annoying since the manual updates do seem to work...
- SCharlieJul 23, 2020Initiate
Please fix Netgear!!!
- Christian_RJul 24, 2020NETGEAR Employee Retired
Hello Everyone,
Thanks for bringing this up. I have forwarded the info to our product teams to have the issue addressed.
Regards,Christian
