Whipsnade
Dec 27, 2022Aspirant
RAX45 Firmware update failure
I've got a Netgear AX4300 Model RAX45, bought just over a year ago. Was running firmware version RAX45-V1.0.11.112_2.0.77 successfully. Updated the firmware to RAX45-V1.0.12.120_2.0.83 and lost ...
- Dec 28, 2022
First, thanks to everyone who responded to my query. I tried several suggestions and still had corrupted firmware. I did, however, find a great solution surfing through YouTube at https://www.youtube.com/watch?v=hXhMgQS5k1o. This came from Richard Lloyd's channel. The process that he describes in over 30 minutes of detailed instructions worked for me. It definitely isn't an official Netgear process nor is the preparation quick. Richard's video can be tough to follow, he speaks quickly so I slowed playback speed to 0.75% and turned on CC and that helped make it easier to follow. I took detailed notes. It's a very involved process, you have to download a couple files and follow the command syntax exactly but it brought back my bricked router. He demonstrates with a router that he intentionally bricked by pulling power in the middle of a firmware flash. If anyone out there has a bricked router laying around you might try this.
michaelkenward
Dec 28, 2022Guru - Experienced User
You could try this;
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
It isn't advised on newer routers. Indeed, I have seen dire warnings that it can damage them. I have no idea about the RAX range.
Whipsnade
Dec 28, 2022Aspirant
- KitsapDec 28, 2022Master
Glad to hear you have your RAX45 back to a functional state.
Both TFTP and NRMPflash are known tools for flashing firmware over the top of corrupted firmware on routers. Not all end users have the skill set to accomplish the task. Thanks for the link to the YouTube video.
