RoadKing12345
Oct 31, 2021Aspirant
RAX45 firmware updates
while using the Nighthawk app, recently started receiving “Firmware check error” messages…. all working well except this new issue…. please advise
Oct 31, 2021Guru - Experienced User
Can ignore it or check NGs FW update web site for the RAX router and see if there is something to manually update if you want too. If it's working, I would not fix it.
- RoadKing12345Oct 31, 2021AspirantThank you…
- FURRYe38Oct 31, 2021Guru - Experienced User
