dmjeziorski
Apr 06, 2022Aspirant
RAX45 Guest Network doesnt connect to internet
Netgear AX4300 RAX45 (Costco version) configured for 2.4GHz guest network will not connect to the internet. This was working and I am not sure when it quit. Other networks are working just fine. T...
Apr 06, 2022Guru - Experienced User
dmjeziorski
The firmware is the version it came with and was running with the initial setup was done. Nothng was changed since.
DaveJ
- FURRYe38Apr 06, 2022Guru - Experienced User
You may want to update fw to this:
Or I see NG put out v.110:
See if this clears up the GN issue...
- dmjeziorskiApr 08, 2022Aspirant
Finally fixed. I did download and install the newest firmware from netgear.com. I did have to install manually since the auto process errored out. By itself that did not fix the problem. Ended up resetting to factory defaults and rebuilding my configuration. No idea why it failed in the first place. But now I am back to working again. Thanks to all for your suggestions.
DaveJ
- FURRYe38Apr 08, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
