JK91's avatar
JK91
Rax45 Install Not Showing Network
Hello.
Attempting to install RAX45 router and following the app process but get stuck at "connect to router's wifi network" because the "NETGEAR##" network is not showing up as available to connect. I have factory reset twice, turned my modem off and on and nothing.
All lights (power, internet, 2.4, 5.0) are lit white.
All antennas are on the correct connection and tight.
I am setting up from my phone and "local network" is enabled.
My old about to fail router works fine (for a bit, which is why it is being replaced)  when plugged into the same network port, so it's not the port.
I don't know the firmware since this is  a new setup and I can't even get past the setup screen to check the basic info. Any ideas?? Did I get a defective unit out of the box?
Thanks for any info
No RepliesBe the first to reply
