Whipsnade
Dec 28, 2021Aspirant
RAX45 issues
I recently acquired an RAX45 — Nighthawk AX6 6-Stream AX4300 WiFi Router and am generally happy with it. I've noticed 2 issues. (1) The Block Sites function doesn't seem to work at all. The User...
- Aug 29, 2022
Apparently the Block Site function is basically vaporware. According to the manual it won't work for any https address. Since pretty much everything is now that makes it a worthless function.
CD_router_888
Apr 25, 2022Guide
Hi Whipsnade ,
Can you share more detail about which sites you can't block ?
https side ? or some domain name fail to block...?
Whipsnade
Aug 29, 2022Aspirant
