amonynuts
Jan 12, 2022Apprentice
RAX45 missing Remote Management option under Advanced Setup
Model: RAX45-100NAS Nighthawk AX6 AX4300 Firmware: V1.0.4.100_2.0.64 In the routerlogin.net configuration menus, I find no option to enable Remote Management under Advanced -> Advanced Setup o...
Jan 12, 2022Guru - Experienced User
Remote Mangagment was removed from NG routers. I believe it may have been due to a security concern. So there using the mobile NH app and Access Anywhere feature on the app to be able to remote in to the router using the Nighthawk app.
amonynuts
That's unfortunate since the Nighthawk app doesn't run on my laptop/desktop computers, and doesn't allow modification of many configuration settings. Thanks for the info.
- FURRYe38Jan 13, 2022Guru - Experienced User
Ya, for any advanced configuration changes, you'll need to be local with a PC or laptop and web browser.
