jodyhama
Aug 23, 2020Follower
RAX45 Nighthawk Router, 802.11ax does not work with Windows10 Laptop
I just purchased a Nighthawk Router with WiFi 6 (AX) at Costco. I got everything set up, except when I tried to set up my Dell laptop with Windows 10. The SSID name did not show up, we tried many t...
whoopersky
Sep 17, 2020Aspirant
I purchased a new Lenovo P15s laptop which was supposed to be able to use 802.11ax.
I have the 802.11ax SSID enabled on my router.
I have updated the Lenovo Intel network ax driver to latest version.
I have installed inSSIDer software.
I cannot see the SSID as a choice on my laptop as a network to join.
I dont see the AX on inSSIDer software either.
I dont know if the router is not working or if the laptop driver can just not see it.
There are many settings on the laptop network driver - so it may be a setting.
Any ideas would be appreciated.
