jodyhama
Aug 23, 2020Follower
RAX45 Nighthawk Router, 802.11ax does not work with Windows10 Laptop
I just purchased a Nighthawk Router with WiFi 6 (AX) at Costco. I got everything set up, except when I tried to set up my Dell laptop with Windows 10. The SSID name did not show up, we tried many t...
whoopersky
Sep 17, 2020Aspirant
I purchased a new Lenovo P15s laptop which was supposed to be able to use 802.11ax.
I have the 802.11ax SSID enabled on my router.
I have updated the Lenovo Intel network ax driver to latest version.
I have installed inSSIDer software.
I cannot see the SSID as a choice on my laptop as a network to join.
I dont see the AX on inSSIDer software either.
I dont know if the router is not working or if the laptop driver can just not see it.
There are many settings on the laptop network driver - so it may be a setting.
Any ideas would be appreciated.
Dan32
Sep 17, 2020Apprentice
Intel just released a major wireless/BT driver update that fixes a long list of issues.
If you don't have version 21.120.2.1, best to give that a try and see if it helps at all. If you're not sure how to figure out what version you have, go to Intel and install and run their support assistant. It will tell you if you need an update. Windows 10 updates, including updating via Driver Manager, may not get you the latest drivers. (That includes Dell's Update version of the same)
