1Fireguy
Oct 29, 2020Aspirant
RAX45 on Fiber network, extend to outbuilding.
I have a fiber optic network to three buildings at my property; a cottage, our house, and a shop/studio barn. Our new Netgear WiFi is not getting into the metal skin barn, but is intermittently access...
Christian_R
Nov 04, 2020NETGEAR Employee Retired
1Fireguy,
You may want to check out the EAX80 WiFi 6 extender.
https://www.netgear.com/home/products/networking/wifi-range-extenders/EAX80.aspx
Christian
- 1FireguyNov 04, 2020AspirantThank you for your reply Christian,
I looked up the EAX80, and I cannot how it obtains the signal that it turns to WiFi, is it hardwired into the wall port, and meshes the SSID with the main router, or is it simply magnifying the original router’s signal?- Christian_RNov 05, 2020NETGEAR Employee Retired
Hi 1Fireguy,
The EAX80 would be an extender essentially extending your router's signal. But because the RAX45 supports WiFi 6 standards, the EAX80 is a great pair to your RAX45 as the EAX80 also supports WiFi 6.
Christian
