AndyPi
Jun 18, 2022Follower
RAX45 Port forwarding rule not accepting comma
Firmware V1.0.11.112_2.0.77 Trying to add a UDP port forwarding rule and no matter what i type, it will not accept comma's in between port numbers. Here is the result I've tri...
Jun 18, 2022Guru - Experienced User
does it work if you add them individually?
I seen a post a while ago that had this same issue that had to add them individual unless they were doing a range
