bdm1955
Mar 31, 2021Follower
RAX45 QOS
In most recent firmware release (V1.0.2.82_2.0.50) for the RAX45, editing the QOS priority appears to be ignored using 'Basic' or 'Advanced' tabs. For example, changing a laptop or TV from "Low" to ...
NotHappy78
Feb 08, 2022Initiate
I have a RAX48 but that's not even available as a selection
We're coming up to a year since this post and the issue still exists. I'm on Firmware V1.0.5.106_2.0.70 and the problem has only gotten worse. I've been trying to troubleshoot which devices may be hogging my bandwidth so I turned on QoS and it has the WORST interface. When you click on attached devices it only shows the first entry, no matter which device you click on it's only going to show you the top one! Then when you edit the entry in order to set the priority list, the setting NEVER saves. The admin console constantly slows down and becomes unusable.
