RaviChopra
Jan 23, 2021Tutor
RAX45 ReadySHARE not recognizing WD My Passport Ultra - USB 3 2 TB drive - HFS+ formatted
I think the title says it all. Using an RAX45 (AX4300). I'm trying to share a USB 3 WD My Passport Ultra 2 TB drive formatted in HFS+, which should be supported. It is powered by USB and this thing w...
RaviChopra
Jan 23, 2021Tutor
Additional detail - apparently it IS seeing the drive, but it's only seeing it as a 200 MB drive where it's really 2 TB.
- RaviChopraJan 23, 2021Tutor
Sorted out the router is seeing the EFI partition, but not the HFS partition. Anyone have any idea how to address this? Extremely frustrating.
Deleted the EFI partition, now it doesn't see the drive at all.
Is the claimed HFS+ compatibility pure bs?
- Christian_RJan 27, 2021NETGEAR Employee Retired
Hello RaviChopra,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
