RaviChopra
Jan 23, 2021Tutor
RAX45 ReadySHARE not recognizing WD My Passport Ultra - USB 3 2 TB drive - HFS+ formatted
I think the title says it all. Using an RAX45 (AX4300). I'm trying to share a USB 3 WD My Passport Ultra 2 TB drive formatted in HFS+, which should be supported. It is powered by USB and this thing w...
RaviChopra
Jan 23, 2021Tutor
Additional detail - apparently it IS seeing the drive, but it's only seeing it as a 200 MB drive where it's really 2 TB.
RaviChopra
Jan 23, 2021Tutor
Sorted out the router is seeing the EFI partition, but not the HFS partition. Anyone have any idea how to address this? Extremely frustrating.
- RaviChopraJan 23, 2021Tutor
Deleted the EFI partition, now it doesn't see the drive at all.
Is the claimed HFS+ compatibility pure bs?
- Christian_RJan 27, 2021NETGEAR Employee Retired
Hello RaviChopra,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
- RaviChopraJan 27, 2021Tutor
I tried that. The advice they gave me was not helpful as it did not address the problem I described to them.
I'm returning the router. As far as I can tell the claim that it supports HFS+ drives is untrue.
