ryfulla
Feb 25, 2024Aspirant
RAX45 router stopped working with xbox apps and consoles
Hey very odd situation. One day my router just stopped working with my xbox and related apps on my PC and phone. Xbox console indicates no issues with internet connection, but it will not access the ...
ryfulla
another update.... I have port forwarded the manufacturer recommended ports (Port 88 (UDP) / Port 3074 (UDP and TCP) / Port 53 (UDP and TCP) / Port 80 (TCP) / Port 500 (UDP) / Port 3544 (UDP) / Port 4500 (UDP)) to my static Xbox IP address to no avail.
Feb 26, 2024Guru - Experienced User
Did you disable uPnP before configuring Port Forward rules?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
