lorumipsum
Aug 07, 2021Aspirant
(RAX45)_slow internet speed on 2.4Ghz
My model isn't listed anywhere that I've seen, but I think the RAX40 is the closest. Mine is the RAX45 6-stream wifi router. I first posted on the general Nighthawk wifi routers group. Thanks michael...
Aug 07, 2021Guru - Experienced User
Its only speed issues on the 2.4gh?
have you tried changing which channels you were broadcasting on?
After the firmware change, did you do a factory reset and reinstall (not from a backup)?
lorumipsum
Aug 14, 2021Aspirant
plemans wrote:Its only speed issues on the 2.4gh?
Yes - speed issues are on 2.4 only.
I had been on channel 9 when things were going well. Promped by your question, I looked again and was back on auto. I have changed it to 11.
I did not do a factory reset, but I did reinstall the firmware.
I'm hoping the channel adjustment cleans things up. If not, I'll try a factory reset and reinstall.
