earthbound
Apr 19, 2021Guide
RAX45 Slow Speeds
I just upgraded my comcast connection from 200mbps -> 400mbps. Since then, I am able to get 450+ mbps straight to my computer bypassing the router. When the router is connected (even with firmware up...
Apr 19, 2021Guru - Experienced User
Are you testing over 2.4ghz or 5ghz?
2.4ghz is much slower and sensitive to interference
- earthboundApr 20, 2021Guide
It's abysmyl on both. Just tested it and I"m getting 47 on the 5G. I can't have this...
- plemansApr 20, 2021Guru - Experienced User
Since you upgraded you servcie, did you try a factory reset and reinstall?
Yes I factory reset it. I am also getting 450+ coming straight from the modem to my computer. Every work computer in the apartment is clocking <100 each time (varies quite significantly between runs)... I don't know what to do. Is this a firmware thing?
