hcohen5055
Mar 21, 2022Follower
RAX45 The Advance tab is grayed out
RAX45, Firmware V1.0.10.110_2.0, OS 11.6.4 The ADVANCED tab is grayed out...can't get to Advanced functions. Why is the ADVANCED TAB grayed out?
Mar 21, 2022Guru - Experienced User
It should look grey until its the tab selected.
Did you click on it?
If you can't click on it, try a different web browser. I've seen reports of safari not working with it.
- FURRYe38Mar 21, 2022Guru - Experienced User
You should contact NG support and ask about a beta thats available to fix this:
