GaryLC
May 30, 2021Aspirant
RAX45 "The IP address conflicts with the WAN IP subnet. Please enter a different IP address."
I am trying to add a Netgear Nighthawk RAX45 WiFi-6 to my network My modem is a Modem/Router Netgear N450 (Cox) There is also a Router Belkin 54G F5D72304 When I get this working, I want to repl...
GaryLC
May 31, 2021Aspirant
Netgear N450 is a CG3000Dv2
I will work on disabling the CG3000Dv2 router.
The problem I had with Cox is that when I first tried to enable the Netgear CM1100, it got part way through and then wouldn't complete the connection. Had to call Cox to trouble shoot. He didn't find anything obvious so we put every thing back to the CG3000Dv2. His suggestion was a service contract to track down the problem. I don't want to be completely down for several days while I trouble shoot connection problems.
GaryLC
Jun 02, 2021Aspirant
Trying several settings to disable the CG3000Dv2 router part of the modem. Not having much success. Somehow, I managed to change the router address and now I can't connect at all. Will take time off work and go home and work on it. Think the only way I can get to the router now is to do a full reset. I am connected through a direct lan connection,not wireless.
I have no idea how the IP was changed. It may have happened when I disabled NAT. But I can't connect and have no way of determinging the current IP address. What ever it is, it is not 198.168.56.xxx. I have some internet connection but it is limited and some sites, like Netgear, won't respond at all. So at the moment, all if FUBAR. So will see what happens with a factory reset and then try to reconfigure to get back to where I was.
Have had good results with Netgear in the past which is why I went that way this time. But really frustrated with an error message that won't give you any indication of how to fix it. Looks like trying to upgrade with the Nighthawk RAX45 was a bad idea. Maybe better to start with a brand new network. Between computers, NAS, TVs etc, I probably have 50 devices potentially on the network. I don't wan't to have to build everything up from scratch.
- antinodeJun 02, 2021Guru
> connection. [...]Nothing I can do about that, whatever it means.
> modem. Not having much success. [...]Not much meat on that bone.
> [...] Think the only way I can get to the router now is to do a full
> reset. [...]That's typically a good way to restore normal operation after
misconfiguration.
> [...] I am connected through a direct lan connection,not wireless.You, personally, are "connected" to what? Some computer or other is
connected to a LAN port on the RAX45, or the CG3000Dv2, or what,
exactly? Wireless devices are on your LAN, too, but I'll take that as
meaning an Ethernet connection between something and something else.> I have no idea how the IP [address] was changed. [...]
Which one? A router has two: LAN and WAN/Internet.
> [...] some sites, like Netgear, won't respond at all. [...]
"Netgear" is a corporation, not a web site. Actual URL? And this is
with what as a modem, and what as a router, connected how?> There is also a Router Belkin 54G F5D72304
Doing what? Connected to what, how? (Hint: If a device has
different types of ports, then "connected to device" is not enough
detail.)> [...] But really frustrated with an error message that won't give you
> any indication of how to fix it. [...]The "fix" is not to try to configure the WAN/Internet interface of
the router on the same IP subnet as its LAN interface.> [...] Looks like trying to upgrade with the Nighthawk RAX45 was a bad
> idea. [...]I'd say that the bad idea was trying to use a CG3000Dv2 as a cable
modem-only when it apparently has no such mode of operation.> [...] Maybe better to start with a brand new network. [...]
If I wanted to make the RAX45 work, then I'd get a cable modem which
will work with your ISP. If they can't puzzle out the CM1100, then I
might try a different maker and/or model.> [...] Between computers, NAS, TVs etc, I probably have 50 devices
> from scratch.What's to "build up"? With a working router, you should be able to
set the router's LAN IP address as you'd like it, and the wireless stuff
(SSID(s), passphrase(s)) to what you had before. Then, with a working
modem, I'd expect all your client devices not to know the difference.I see that I overlooked this earlier:
> Also, what is with the MAC address?
> 08:36:C9:8E:5E:43 (MAC address on the Box)
> 08:36:C9:8E:5E:44 (Router Mac Address) on the Internet port.
> There must be 2 MAC addresses but what are they?
Every network interface has a MAC address. A router has two network
interfaces, LAN and WAN/Internet. Which MAC address you want depends on
the interface of interest. I'd expect both to appear on the ADVANCED >
ADVANCED Home page in the router's management web site.- GaryLCJun 02, 2021Aspirant
I have a desktop computer directly connected to a wired LAN port.
Restoring the CG3000Dv2 router to original settings got me back to where I was before. And I am back on-line.
The Modem LAN IP was changed. I don't know to what. I couldn't connect to it at all, thus the reset. But the IP inconstincies reaked havoc throughout my network. I could get to Facebook, but the website for THIS forum (https://thf-membership.s3.amazonaws.com/2019_08_0309_GunControlEBook_V5.pdf?mkt_tok=ODI0LU1IVC0zMDQAAAF9XnvpZjEpYiIkxNzD3-RKlTfihFOQT4jBs2K-baF7LrOQ6XQk_ttkQ3HR2INWKALiObrZlmo2nRYikfxRE0zT9MtUhGaSizyrl0bf61DzcQVqucjd) was totally unavailable. Gmail was completely baffeled by the conflicting IP addresses and shut me down-also wouldn't let me enter passwords either. Using the CG3000Dv2 modem/router with an unknown IP address. I assume it was the LAN IP address since I couldn't connect to the modem through the LAN.
BTW, the CM1100 is specifically identified as being compatible with COX.
>modem, I'd expect all your client devices not to know the difference.Exactly what I would expect, what I have done in the past with outher routers (even with multiple routers) and as long as I set the routers IP addresses not to conflict with other devices, it has worked. I will keep trying.
- GaryLCJun 12, 2021Aspirant
Try again.
“The IP address conflicts with the WAN IP subnet. Please enter a different IP address.”
Still getting this error when I try to create a local subnet.
LAN Setup
Device Name : RAX45
LAN TCE/IP setup
IP Address 192.168.56.200
IP Subnet Mask: 255.255.255.0
RIP Direction: Both
RIP Version: Disabled
Use Router as DHCP Server
Starting IP Address 192.168.56.201
Ending IP Address 192.168.56.254
So look at WAN IP:
WAN Setup
N Disable Port Scan and DoS Protection
N Default DMZ Server 192.168.1.0
N Respond to Ping on Internet Port
Y Disable IGMP Proxying
MTU Size(in bytes) 1500
NAT Filtering Secured
(Absolutely nothing here about WAN IP Subnet)
Internet Setup
Does your internet connection require a login? `No
Internet IP Address: Get Dynamically from ISP (but doesn’t matter if I try to use a static address)
Domain Name Server (DNS) Address Get Automatically from ISP
Router MAC Address Use Default Address
So the message provides no information about what is causing the error. Lot of people on the boards have this error and have difficulty fixing it. There are not IP conflicts using 192.168.56.200-192.168.56.254. There are other devices using 192.168.56.xxx but not this block. I have used multiple routers in this network in the past, including Netgear, and as long as the addressing doesn't conflict, there has not bee a problem. The error message is not useful in solving the problem.
It will let me use 192.168.1.xxx but I don't want to use that.
