Gazzerk's avatar
Gazzerk
Tutor
Jan 21, 2021
RAX45 unable to login or activate password recovery
I have not had to login in to my router for a few months. Received a security email for firmware update. I am on a Mac so all my passwords are stored in Keychain Access. Always confirm them before lo...
  • plemans's avatar
    Jan 22, 2021
    If you change the ssid to the same ssid you had prior, then you shouldn't need to.
    but if you change it to something else then you will need to
