dbird
Aug 28, 2020Aspirant
RAX45 Upside down mount?
I've mounted my new router AZ4300 Nighthawk Model RAX45 on the ceiling of a room near the center of my house. See below attached file for a picture. The unit is attached using the built-in mounting a...
Christian_R
Sep 03, 2020NETGEAR Employee Retired
Hi dbird,
We do recommend that the router is set up-right.
Christian
- LurksalotSep 03, 2020Apprentice
This makes no sense. Then one could make the case and ask, why are there mounting "points" at the bottom of the router (?) Sure you could secure it upright so it does not slide off somewhere, etc. Mine is vertical on a wall secured with the mount points.
-Thanks.
- dbirdSep 03, 2020Aspirant
Christian_R wrote:Hi dbird,
Christian
Thanks for the reply. May I know the reason for this recommendation?
Dave
