Shotout
Jul 27, 2021Follower
RAX45 Using tons of data
My router is using an inordinate amount of data, well beyond any of the devices that I have attached to it. Does anyone know if there is something in the software setup that I can adjust to lower th...
Jul 28, 2021Guru - Experienced User
Try disconnecting all the devices from it. If its still using the data, it could be the router. If the data usage stops, its one of the devices connected.
