frankie6737
Aug 23, 2020Aspirant
RAX45 VPN not working
Activated VPN service but cannot connect to router via VPN. Checking log and found that [OPENVPN] NTP sync time failed. Get correct system time then reconnect. Sunday, Aug 23,2020 08:40:44 tr...
frankie6737
Sep 05, 2020Aspirant
Tried both 1.0.2.28 and 1.0.2.66(latest update) but still didn't work. Same log found
Christian_R
Sep 11, 2020NETGEAR Employee Retired
Hi frank6737,
Thanks for confirming. Have you had a moment to get in contact with our support team regarding this?
https://www.netgear.com/support/default.aspx
Christian
- frankie6737Sep 17, 2020Aspirant
I did but they just ask me to call for tech support. it is still no clue about the issue
As a long-team Netgear customer I reallly frustrate about the current tech support. I will look for different router brand to replace it.
