maurice00
Jan 03, 2021Aspirant
RAX45
I can't get a list of Ports forwarding, and can't add a redirection to a port that USED to exist on a dead machine to a different live one. All I get is FAILED messages. Is there any way to fix this ...
Christian_R
Jan 08, 2021NETGEAR Employee Retired
Hello Maurice,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
