Rugershooter
Nov 17, 2021Tutor
RAX48 - Air Play Freezes
Purchased a RAX48 router upgrading from a 7400 AC2600. Airplay from my iPad to a Windows 10 laptop freezes. Laptop is wire connected and iPad on wifi. Support had me adjust channels from Auto to...
Nov 17, 2021Guru - Experienced User
Is the ipad connected to the 2.4ghz or the 5ghz?
What modem/gateway do you have?
what firmware is on the router?
Rugershooter
Nov 17, 2021Tutor
Appreciate you looking to help.
Firmware: 1.0.4.100
Modem: Netgear CM700
I will check the wifi.
Firmware: 1.0.4.100
