Rugershooter
Nov 17, 2021Tutor
RAX48 - Air Play Freezes
Purchased a RAX48 router upgrading from a 7400 AC2600. Airplay from my iPad to a Windows 10 laptop freezes. Laptop is wire connected and iPad on wifi. Support had me adjust channels from Auto to...
Nov 17, 2021Guru - Experienced User
For you future needs, Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
