ChungKing
Jan 30, 2022Aspirant
RAX48 - How to get USB drive to show up in Windows 10?
I had an old Linksys router that had a USB drive connected to it. No problems other than the drive acting slow sometimes. I needed a faster router with better range. I found a good deal on an RAX48. ...
Razor512
Jan 30, 2022Prodigy
Wanted to further clarify the VPN app aspect of things. If a VPN application is set to allow local traffic, it will often still cause mapping issues, but after a drive is mapped, it will continue to work fine when the VPN software is subsequently launch.
It is a common bug, as the companies making these applications don't seem to test for such a use case, and they offer no good way to report the issues either.
ChungKing
Feb 02, 2022Aspirant
No VPN. I tried your instructions and they work on desktop (wired). I can't get it to work on laptop (wireless).
\\192.168.1.1 is not accessible. You might not have permission to use this network resource. Contract the administrator of this server to find out if you have permissions. Access is denied."
- Razor512Feb 02, 2022Prodigy
If you go to the network folder in the file explorer window, does it warn you that the network discovery service is disabled?
