stevengates45
Apr 23, 2021Tutor
RAX48 160MHz
I have an RAX48 and I’m trying to see which channels It’s communicating on. I’d like to verify that it’s actually communicating at 160MHz when I select HT160. Anyone know the best way to do this?
- Apr 23, 2021
have you tried using inssider or acrylic wifi scanner?
Apr 23, 2021Guru - Experienced User
stevengates45
Apr 26, 2021Tutor
Acrylic WiFi scanner worked great. Thanks for the tip!
