A5W4eXCNhzArsec
Sep 25, 2021Aspirant
RAX48 5GHz wifi unstable with MacBook Pro M1
MacBook lost internet connection intermittently while connected to 5GHz wifi. No issue with other devices or when MacBook is on 2.4GHz wifi.
Razor512
Sep 25, 2021Prodigy
What happens if you disable the smart connect function on the router, and connect to just the 5GHz band?
This can help determine if it is having an issue with theband steering function that is part of smart connect.
- A5W4eXCNhzArsecSep 25, 2021Aspirant
If that's the issue, is it a bug in SmartConnect?
- Razor512Sep 25, 2021Prodigy
Potentially, it depends on how these issues are handled. Normally a client device should respect a band steer when the router tells it to use a specific band, but some devices may not, and in those cases, either that device will need a WiFi driver update to better handle bandsteering, or the router will need a workaround to not retry bandsteering on certain devices.
Netgear uses the smart connect to segment older standard devices and newer ones as well as handling band steering when the device is far enough away that the 2.4GHz band will be more reliable than the 5GHz band. Under normal conditions, it improves overall simultaneous throughput when many devices are active at the same time, as you get fewer airtime sharing issues.
Currently the vast majority of devices work well with smart connect.
So the pros outweighs the cons for SmartConnect?
