brucescar
Nov 29, 2020Aspirant
RAX48 cannot transfer large files with USB drive
I have an external drive connected the USB3 port on the router. When transfering large files, I get 0x8007003b errors. When playing large video files, after a few minutes, the stream will drop. I rec...
brucescar
Nov 30, 2020Aspirant
Thanks, it's a WD passport 1TB. There's no preloaded software or encryption. It works at first glance, I can see all files, add it as a network drive. I only run into problems transferring large files, or streaming large videos.
brucescar
Sorry my model is rax48. I couldn't find it on the model list. I thought I left it blank. Is it possible to edit my post? I couldn't find a link to edit.
This thread seems to have my same problem, https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/RAX80-Problem-with-Readyshare-Large-File-Transfer/td-p/1908686
