flagrant992
Nov 29, 2020Aspirant
RAX48 DHCP Broken
I just got the RAX48 AKA AX5200. The DHCP Server keeps giving out same IP to different MAC's. Can someone please fix this. Firmware Version V1.0.2.72_2.0.45. Also the sorting in the attatched device...
- Nov 29, 2020
Note: I changed Ending IP Address to 192.168.1.199. I often use somes static IP's above 200 so not sure if that had something to do with it. Regardless I got around it using Address Reservation for all my devices which seems to take care of the issue. I am assigning all of them above 200 away from the DHCP pool.
flagrant992
- Christian_RDec 02, 2020NETGEAR Employee Retired
Hello flgrant992,
Thanks for providing an update as it may help others.Christian
