rowemesp
Nov 01, 2022Aspirant
RAX48 Firmware problem. . .locking me out
I've noticed that when accessing firmware settings (RAX48) over my LAN that I can successfully login and change settings after a fresh reboot of the router. If during that session I have ANY problem...
rowemesp
The RAX48 is running firmware v1.0.11.112, which I believe is the latest version.
The RAX48 is connected to directly to the ONT (Verizon FIOS) with CAT5 cable (not a modem / ONT). I don't believe there's a cabling problem, as I made it (cable) myself and tested the connectors on each end and have been using it for a few years without issue. I've tried connecting to the RAX48 via WIFI as well as with a wired connection with the same results.
I did reset and restore a backup config (known to work) a few days ago. The router DOES work, but as stated earlier, if something goes wrong with a setting change then it prevents getting back into it until it's rebooted.
michaelkenward
Nov 01, 2022Guru - Experienced User
Not advised when you experience problems with a router.
Restoring may simply revive the bug that has bitten you.
If the behaviour has started with new firmware, then rolling back to an earlier version could help.
- rowemespNov 01, 2022Aspirant
This "bug" has existed since the day I bought it 6+ months ago and through at least one firmware update. Since the router's basic functions were working, I didn't bother complaining about it until now. I can work around it, but if it could be fixed, that would be great.
- FURRYe38Nov 01, 2022Guru - Experienced User
CAT5 isn't rated for 1000mpbs. Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Factory reset with out using the backup configuration file is recommended. I might manually re-load the FW file on to the router. Do this with the router disconnected from the ONT. After the router is reloaded with FW. Factory reset the router and setup from scratch.
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200 as well.
Thanks for the suggestions. I try them and let you know how it works out. --Rob
