xgourmet
Jan 19, 2022Guide
RAX48 Firmware Update - GUI language file is invalid
I tried to update the firmware of my RAX48 router and get the following error: GUI language file is invalid Firmware Update Assistant New firmware is found. Do you want to update the firm...
Jan 19, 2022Guru - Experienced User
have you tried manually updating?
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
xgourmet
Jan 20, 2022Guide
Unfortunately the firewall on my company issued laptop prevents me from downloading the file from
https://www.downloads.netgear.com/files/GDC/RAX48/RAX48-V1.0.5.106_2.0.70.zip
doesn't the automatic updater download the same file? are there any other options?
- plemansJan 20, 2022Guru - Experienced UserTry on a non work computer
