xgourmet
Jan 19, 2022Guide
RAX48 Firmware Update - GUI language file is invalid
I tried to update the firmware of my RAX48 router and get the following error: GUI language file is invalid Firmware Update Assistant New firmware is found. Do you want to update the firm...
xgourmet
Jan 20, 2022Guide
Unfortunately the firewall on my company issued laptop prevents me from downloading the file from
https://www.downloads.netgear.com/files/GDC/RAX48/RAX48-V1.0.5.106_2.0.70.zip
doesn't the automatic updater download the same file? are there any other options?
Jan 20, 2022Guru - Experienced User
Try on a non work computer
