Marc2023
Jul 29, 2023Aspirant
RAX48 Firmware Upgrade Failed
My RAX48 failed to complete a firmware update. Ended up having to do a factory reset. Now it works for a week or two then looses access to the internet. Since it is no longer under warranty , i...
Marc2023
Thanks for the info.
Tomorrow I will try upgrading the firmware to version V1.0.15.128 on my RAX48 using the manual process to see if this fixes the issue.
Not 100% convinced this will solve the problem because I did a factory reset and the router has been unstable ever since?
I know it isn't the modem issue because I purchased an AX1800 and it connected no problem
Kitsap
Jul 29, 2023Master
Marc2023 wrote:Thanks for the info.
Still does not answer the question about the manufacturer and model number of the upstream modem.
Your AX1800 is what model number specifically?
