RAColling
Feb 13, 2022Aspirant
RAX48 Hangs
Actually an RAX48. About 3 days ago it started hanging every 2 or 3 hours. To fix I would pull the plug and reboot. After applying Firmware update V1.0.5.106_2.0.70. It kept hanging at about 8 hours....
Feb 14, 2022Guru - Experienced User
Have to do a whois lookup on that IP address to see where it's coming from...
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
A factory reset maybe needed.
RAColling
Feb 14, 2022Aspirant
RAX48 -
I did all that early on. I am going to do that again since the first time it was before the router update.
