SurfBird
Nov 06, 2022Follower
RAX48 Held reset too long and now power light is solid red
I was having troubles with the router. I reset it once and it did not work. So I tried again and I held it longer in case that somehow makes a difference. Now there is only a solid red light that tur...
michaelkenward
Nov 07, 2022Guru - Experienced User
You have probably put it into "recovery" mode.
It might be simply a case of rebooting it. Have you tried that?
If not, can you access the browser graphical user interface (GUI)?
