ogansemoi
Nov 16, 2022Follower
RAX48 high latency via Ethernet
Using Speedtest my wireless connection on my iPhone is stating 800mbps down with ~10ms of latency on Detroit servers (around where I live), while on my PC over Ethernet it is at 700mbps down with o...
Nov 17, 2022Guru - Experienced User
Are you using any virus protection/security on your pc?
Or is it running through a managed switch/smart switch?
If the phone is fine, it tends to indicate the latency is coming from either the pc or a switch/device its connected to.
- quandaledingleNov 17, 2022Aspirant
I am not using any virus protection on my PC besides the stock Windows antivirus, even then I haven't interacted with it before and it has never given me any issues. I am also not running it through a switch, it's just a straight Ethernet into the back of my PC from the router.
