davesolo
Jan 22, 2023Aspirant
RAX48 internet dead
All the lights are on and isp service is up and running. I can’t contact support because I don’t have a contract or whatever. Any advice? Nighthawk AX6 6-Stream AX5200 WiFi Router (RAX48) Tha...
davesolo
Jan 23, 2023Aspirant
Hello, I tried doing a factory reset and that worked for a bit now it’s back to what it was. I also tried changing the dns settings to google primary and secondary. I am still getting this error when I try to open google: This site can’t be reached. Googles dns address could not be found. DNS probe started
Jan 23, 2023Guru - Experienced User
So if you factory reset and setup from scratch and this time do not change the DNS settings on the router, does the router work for a good while?
