NoWay-NoHow's avatar
NoWay-NoHow
Follower
Dec 11, 2020
RAX48 is a mess
I recently purchased a RAX48 router. This was to replace my old ASUS RT-AC56U that I have had for serveral years, as this router theoretically is much slower and on occasion (once a week) would require a hard reboot. I have had nothing but troubles sense setting up the RAX48 though. I have had random drops of the 5 Ghz signal where it required a reboot of the router before it reappeared, onstant drops of internet speeds where I wouldn't even be able to load a webpage on my phone, and constant dropping of connectivity from wireless devices and then reassignment of IPs.
I have already tried a factory reset and manual reinstallation of the latest firmware (1.0.2.72). Any other options besides returning it and not buying a Netgear product again.
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello,
    If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
    https://www.netgear.com/support/contact.aspx
    Christian
