chippyx
Jun 22, 2022Tutor
RAX48 Missing channel 149 and above
Hi, I have a RAX48 in the US with Firmware Version V1.0.11.112_2.0.77. It is missing channel 149 and above with 5 GHz. How do I get it back? Thank you!
- Jun 22, 2022
Are you using "up to 4800mbps" setting? If so, thats a 160hz wide channel.
because its such a wide channel, there's only 2 in the 5ghz spectrum. From channels 36-64 and from 100-128
to use the higher channels, you'd have to set it to "up to 2400mbps" which reduces the channel width to 80hz wide and then there's 6x channel ranges available.
