IceBearDoesNet
Dec 24, 2020Aspirant
RAX48 Netgear Armor not activating
I just purchased the Netgear Nighthawk AX5200 (RAX48) and when I go to activate Netgear Armor, I get the "Process is taking too long (more than 60 seconds), Try again. Is there another way to activa...
Christian_R
Dec 30, 2020NETGEAR Employee Retired
Hello IceBearDoesNet,
Just to confirm, you're using the Nightawk app to activate Armor, correct?
Christian
- IceBearDoesNetDec 30, 2020AspirantYes, I am using the app
- Christian_RDec 31, 2020NETGEAR Employee Retired
Hello,
Thanks for confirming. May you power cycle your router and if your issue persists, please send me a private message with your email address and serial number.
Christian
