RS1226
Oct 14, 2021Guide
RAX48 Nighthawk AX6 AX5200 - red power light and red internet light
Router is displaying solid red power light AND solid red internet light. Please provide your suggestions on how to correct. Thank you.
- Oct 14, 2021
What verizon modem is it?
Some have their own integrated routers that cause a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-ModeSee if you can access it via an ethernet connection.
Also, the RAX48 has a wifi on/off button. That could have gotten hit by the toddler. A factory reset doesn't clear that out because its a hardware setting. Push and hold it for 2 seconds.
RS1226
Oct 14, 2021Guide
No change after the factory reset. Both lights are still solid red.
Oct 14, 2021Guru - Experienced User
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
- RS1226Oct 14, 2021Guide
I haven't tried the recovery yet (not enought time to devote to it presently), but the solid red power light is now suddenly solid white. Only the solid red internet light remains. Any other suggestions other than the recovery? Thank you.
- plemansOct 14, 2021Guru - Experienced User
Tried that Wifi on/off button and the 2.4 and 5 GHz networks are solid white. Internet is still showing solid red, but I have internet. I guess I'll just accept it and move forward. Thank you for your help!
