xgourmet
Oct 29, 2020Guide
RAX48 Router
I'm trying to find more information on the RAX48 — Nighthawk AX6 6-Stream AX5200 WiFi 6 Router that is currently on sale at Best Buy. Is this a stripped down version of the RAX50 made for Best Buy? Looking at the specs, they look almost identical, can you let me know if there are any differences in these models? I consider upgrading my current Netgear R6900
1 Reply
- rinthosLuminaryThe RAX48 is the RAX50 but the 2.4ghz max speed is reduced from 600mbps to 460Mbps
256QAM vs 1024QAM
The firmware appears to be nearly identical just that 1 tiny difference.
Hope this helps.
